Home > Forums > Software User Forums > Siemens > STAR-CD
No steep rise in pressure curve
Old   March 16, 2015, 22:34
Default No steep rise in pressure curve
Balaji
srivathsanpoyyapakkam is on a distinguished road
I am currently simulating HCCI Mode of Combustion with n - heptane as the fuel. My problem is that I am unable to get a steep rise in the pressure curve although I have a considerable amount of heat release (perceived from the spd file) I have given the following parameters as the input
1. combustion model - ECFM-3Z
2. Cetane no - 60
3. Eq ratio - 0.29
4. EGR - 0%
5. Initial Pressure - 6.14 bar
6. Initial Temp - 503K
7. Injected Mass - 4.716e-4 kg/s (pls tell me whether this mass is sufficient for combustion or not)
Should I need to change any of the ignition parameters?
srivathsanpoyyapakkam is offline   Reply With Quote
Old   March 19, 2015, 02:42
Can
cnaksoy is on a distinguished road
Firstly, what is your injector hole diameter? You should write its diameter values as meter (m) in Pro-Star.
And I guess eq ratio should be bigger, for example 0.85. I usually use Lambda value for air/fuel mixture.(Lambda = 1.5-1.8 for diesel engines).
I am not sure about the mass of injected fuel. Maybe you should check it by using 1D simulation.
2. Cetane no - 60
3. Eq ratio - 0.29
4. EGR - 0%
cnaksoy is offline   Reply With Quote
Old   March 19, 2015, 03:05
Balaji
Thanks for the reply. My injector hole diameter is 0.188mm. I have found out that my injection mass was not sufficient for combustion.
Can you please help me in deciding the ignition model ?
Old   March 19, 2015, 03:44
Can
I will try. what do you need?
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 12:43
pressure coefficient on hip roof low rise building maaz FLUENT 0 February 10, 2014 02:50
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
rotating domain - pressure rise petp CFX 2 April 5, 2008 07:03
