September 10, 2015, 06:09 |
Cylinder inflow simulation
Pradeep
Rep Power: 11 |
i couldnt solve a simple cylinder flow problem.,. can anyone help me?
September 17, 2015, 05:20 |
Can
Rep Power: 13 |
October 6, 2015, 10:23 |
Couldnt export surfaces from CATIA v5 to star CD
Pradeep
Rep Power: 11 |
October 8, 2015, 05:57 |
Can
Rep Power: 13 |
I don't know you can use Hypermesh just to define the engine components but it is really too easy in Hypermesh. Maybe you can look some tutorials for Hypermesh. The other way, you can define engine components in StarCCM+, but it is more complex in StarCCM+. You should check tutorials. I guess you define the engine components in Catia. if yes, you can try to export your CAD model as .stl format. Maybe it can work in STAR-prosurf. |
November 5, 2015, 02:32 |
Pradeep
Rep Power: 11 |
Thank you. I solved the case. But couldnt animate the flow in pro-star. how to animate the flow motion?
November 5, 2015, 02:39 |
Can
Rep Power: 13 |
I can't animate the results in Pro-star as well. But you can take the picture of results which you want, and then combine them in windows movie maker. I guess this is the best way.
I use a code to export all pictures automatically in pro-star. if you share your email with me, ı can provide the code for you. But now ı am at work, ı can send the code tou you when ı am at home. ok? |
November 5, 2015, 03:30 |
Thank you
Pradeep
Rep Power: 11 |
Sure sir. And also send me the steps if its possible to extract graph from the plots displayed. Kindly send it to my mail id : pradeepboss616@gmail.com
Thank you once again |
Display Modes | |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 07:01 |
Large eddy simulation for flow around cylinder | ash_kul999 | OpenFOAM Running, Solving & CFD | 5 | April 18, 2015 05:47 |
simulation of cylinder vibrating | ali moghimifar | FLUENT | 2 | March 2, 2012 14:18 |
modification for rotating cylinder simulation | zonexo | Main CFD Forum | 3 | July 21, 2006 15:24 |
Simulation of the Flow past a circular cylinder using STAR-CD | M. S. GUEROUACHE | Main CFD Forum | 0 | October 1, 1998 11:51 |
