Home > Forums > Software User Forums > Siemens > STAR-CD
Temperature greater than maximum range
Old   July 23, 2009, 21:08
Default Temperature greater than maximum range
SAKTI
byanw81 is on a distinguished road
Dear friends,
how to solve this warning :
warning 069 : Temperature greater than maximum range
I am using polynomial setting for the material, if I remove to constant the problem is gone, any idea?
thanks
Byan
byanw81 is offline   Reply With Quote
Old   July 24, 2009, 10:45
Pauli
Pauli is on a distinguished road
Sounds like you need to extend the range of your polynomial. In other words your polynomial is defined over a certain range, lets assume it is 300K to 900K. StarCD is calculating a cell has temperature greater than 900K. So StarCD is letting you know you are outside the valid range. This may or may not be a problem. You should check the polynomial behavior at the temperatures calculated. If the polynomial provides reasonable values, you should be able to ignore the warning.
Pauli is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
the maximum value of granular temperature haijj FLUENT 0 August 25, 2008 05:02
Allowable maximum temperature Atit Koonsrisuk CFX 0 January 27, 2004 01:16
Urgent help needed in finding maximum temperature. Deadly FLUENT 3 September 3, 2002 08:43
Too high maximum gas temperature Ossi Siemens 4 October 11, 2001 05:13
