June 11, 2009, 00:22 |
finding drag coefficient in laminar flow
kamal
hi all,
i am doing the flow analysis across a cylinder (2d laminar flow).i am facing the problem in calculating the drag coefficient.it is not matching (whatever the value comes from the erd file in star-cd)with the analytical result. i have few doubts. 1.whether the erd file is valid only for turbulent case 2.what is the definition of tx,tyforce in the erd file in star-cd an how to get cd and cl from tx and ty force. 3.whether any other method is there in calclation of drag coeff. regards. Last edited by ksatpathy; June 11, 2009 at 00:28. Reason: to get more accurate idea |
October 19, 2009, 11:46 |
Rep Power: 21 |
hi ksatpathy,
a little bit late, but maybe it will help anyway. maybe there's some other user searching the forum... 1) erd-file should be valid for laminar and turbulent flow 2) the erd-file looks like sx, sy, sz, nx, ny, nz, tx, ty, tz with sx = shear force in x-direction nx = normal force in x-direction tx = total force in x-direction other directions accordingly directions according to coordinate sys 1 in pro-star calculate the lift and drag coefficients like you would do it in the analytical calculation. i think, you have used the formula to get the analytical solution. 3) i don's know any other methods maybe your solution differs from the analytical solution, because it is a unsteady problem. there will be a karman vortex street behind the cylinder. the seperating vortices will cause a oscillation of the forces, while you're looking on just one value (printed in the erd-file). try a transient simulation and repeate the calculation with the time averaged values. regards |
October 22, 2009, 04:05 |
reply
kamal
thanks a lot mr.abdul for your kind information.
regards, satpathy. |
January 14, 2010, 10:43 |
Question
Alexander Molero
Can you help me to find drag coefficients in laminar flow to irregular shape (Underwater Vehicle)? Any book or Paper (in this mean, teorically)? And if i can use the model 3D-CAD (generated in Wildfire Pro-Engineering) in CFX-Post (in this mean, estimated)?
Regards, Alex |
Display Modes | |
Drag of a sphere in laminar flow | harly | OpenFOAM Running, Solving & CFD | 1 | February 4, 2009 06:27 |
How to enforce laminar flow while using k-e | Grzegorz Kondora | FLUENT | 0 | January 28, 2009 10:35 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Laminar Heat Transfer Coefficient | Shawn | Main CFD Forum | 2 | September 23, 2004 22:30 |
FInding Drag Coefficient | Sridhar | FLUENT | 3 | December 2, 2001 21:22 |
