September 28, 2009, 10:24 |
Memory/ swap area
Jaco
Rep Power: 16 |
Hi there
I'm running pro-star/amm and when I run my auto mesh wizzard and I execute step 2 (prepare suface) the program starts running and then close down without any error message. I think this is memory related? I have run Prosize a couple of times to increase my memory values but this seems that it keeps on giving me small values of memory required (>> 4Gb). Is there a way to specify a chunk of memory? I read some threads on setting the swap memory size - what command will I use to do that? I'm running windows, 32bit, 4Gb Memory, 2.1GHz duo-core, pro-star v4.10. Thanks, J |
September 29, 2009, 19:43 |
Rep Power: 17 |
I don't know if this is memory or not, but if you have 4GB of memory and a 32bit system, there is nothing you can do with swap to add more memory. Windows 32 will never use more than roughly 3.5GB of memory no matter what you do to it. You might have to go to a 64bit OS.
close, memory, swap area |
Memory error? | Young | CFX | 3 | September 30, 2008 11:33 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Storing Surface Area of each cell in a file? | Markus Alzon | FLUENT | 0 | June 21, 2007 08:38 |
Memory Problems | David Baker | Siemens | 5 | March 1, 2007 21:04 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 17:50 |
