Home > Forums > Software User Forums > Siemens > STAR-CD
ignition treatment for gdi engine
Old   June 13, 2011, 04:33
Default ignition treatment for gdi engine
mepgzzi is on a distinguished road
Hi all,
Im trying to simulate a gdi engine working under the homogeneous mode by using the ebu latct combustion model and the numerical ignition model.
The problem i have is that it fails when igniting. There are altogether 16 cells set to be the spark and the equivalence ratio and temperature at the spark timing reach around 0.8~0.9 and 680K respectively
My question is: what is preventing the ignition? Is the temperature too low for that? if yes is there any constant or switch to set to change the allowed ignition temperature for ebu models? are there any other methods to ignite the mixture other than using the default model(e.g. applying sorent.f to the case)?
Thanks!
mepgzzi is offline   Reply With Quote
Plz help me "creation IC engine Geometry" khalaf FLUENT 8 September 28, 2016 02:10
Tutorials for Sprark Ignition Engine Santosh FLUENT 0 July 12, 2007 03:12
Premixed combustion in Spark Ignition engine kevin FLUENT 1 June 23, 2006 03:59
Ignition modeling Julie Polyakh Siemens 0 May 20, 2004 09:05
spark ignition engine Hennie van der Westhuizen Main CFD Forum 2 January 15, 2002 12:59
