September 14, 2011, 03:53 |
star cd convergence error
hi im a chemical engineering post graduate student and i have to model and simulate a tray dryer using STAR CD and im somewhat new to CFD. i started my model as a .IGES file and created the surface mesh in pro-surf as a .dbs file n then as a .mdl file in pro amm. when i run the model there are convergence errors and when i check the residuals and browse the standard output file, after 2 iterations there is an error message saying,
"FLUID FLOW DETECTED AT SOME OUTFLOW BOUNDARIES MASS FLUX IS FORCED TO ZERO. IF THIS CONDITION PERSISTS, YOUR CALCULATIONS MAY BE WRONG " the mesh didn't get converged after 100000 iterations. my mesh got around 1 500 000 fluid (air) trimmed cells, with 5ms-1 air speed at the inlet and flow is steady state and laminar. used SIMPLE method to solve it. and in the star guide panel, i make all the input parameters like i did in the STAR tutorial 2nd example, (flow in a partially blocked elbow). im new to CFD and STAR CD and spend considerable time to figure out whats wrong with my model .. can you please give me some advice? |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
