September 2, 2011, 23:40 |
About trim polyhedron of Es-ice
zheng jianjun
Rep Power: 16 |
I use Es-ice/Trimming method to create the moving grid,but I meet this problem when I select "polyhedron" option during trim process.(My version is 4.14) It shows as following:
Store the Port 1 trimmed in database ID 122. Saved: trimmed cell data with id 122 Port 1 trimmed Cells Cell Tbls CP Match CP Tables Splines Splin Tbl Vertices 91869 1 0 0 0 0 737885 ID 697976 1 0 0 0 0 809450 The curtain is not well defined for 7 faces of Port 1. Failed to find the collapsing layers for Port 1. The curtain is not well defined for 7 faces of Port 4. Failed to find the collapsing layers for Port 4. "Trim,Recover" may allow you to fix the problem and continue. Failed to cut the Template. However, when I select "cell division" option during trim process, it can finish the process. But the output grid includes several crack cells. I have tried to modify the 3D template,trimming splines set, and also the trim parameters.Unfortunately, I haven't found the right way to solve it. If somone has some experiences about how to deal with this problem,please tell me. thx. |
November 7, 2011, 02:24 |
zheng jianjun
Rep Power: 16 |
It maybe because of the gemometry file problem, and when I change the distance between the valves and the valve seat from 0.05 to 0.1, the trimming process can finish the work.
ice melting simulation | pratikmehta | ANSYS | 3 | April 17, 2013 09:52 |
Ice Accretion using Fluent | Virk | FLUENT | 2 | December 22, 2012 04:14 |
Ice melting Simulation | pratikmehta | CFX | 13 | February 29, 2012 21:14 |
Right tool for ice flow? | mankoff | OpenFOAM | 2 | November 7, 2010 03:40 |
two phase flow + ice phase and breaking | soeren87 | OpenFOAM Running, Solving & CFD | 0 | September 19, 2010 10:20 |
