Home > Forums > General Forums > Structural Mechanics
Delta Functions within Ansys Mechanical
Old   May 18, 2013, 20:02
Default Delta Functions within Ansys Mechanical
Stephen Waite
Stephen Waite is on a distinguished road
Hi All
I'm performing a 1-way FSI using ANSYS mechanical and CFX.
I am creating displacements in mechanical using the direct FE displacement feature which is working nicely but I'm trying to make it a bit more complicated. I wish to use a series of displacements that begin at different times (they need to be dependent on space and time so i cant just use the tabular feature) so i was wondering.
Does the functions option for components have a delta function option?
Is it possible to use if statements within the functions option
Is there a list of available functions. (i could maybe approximate a delta using Bessel functions)
Is there a list of variables for the functions option.
I've been looking online for the last week I'm still trying to get access to the ANSYS portal tutorials so apologies if the answers are on there I'm a student so don't have my own license.
Cheers
Stephen Waite is offline   Reply With Quote
Old   June 5, 2013, 11:55
Erik
evcelica is on a distinguished road
I thought you could get onto the portal by creating an account using your customer number. If you open Anslic admin utility on your schools computer you can find your customer number, that's what I did at work. It doesn't have to be your personal license.
evcelica is offline   Reply With Quote
Old   July 29, 2013, 08:56
Florin's Avatar
Florin Gheorghe
Florin is on a distinguished road
I am not sure about your problem, but you can make your analysis in several steps; you can define loads on several locations and thru steps you can specify what would be the magnitude and the start and stop.
Best regards,
Florin
Florin is offline   Reply With Quote
ANSYS Mechanical APDL mechanicaldesign ANSYS 2 December 30, 2018 02:44
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
ANSYS 13,14 or 14.5 unable to start mechanical editor fesat181 ANSYS 4 November 15, 2014 20:24
Exporting fluent melting/solidification model results to ansys mechanical apdl omair11 ANSYS 3 August 28, 2013 06:22
Static structural analysis using ANSYS Mechanical APDL sds10 ANSYS 1 June 23, 2012 00:25
