Home > Forums > General Forums > Structural Mechanics
connecting sketch and model!
Old   September 11, 2014, 06:42
Default connecting sketch and model!
Jon
pink61ir is on a distinguished road
Hi everyone,
I have a weird question! I have a 2d frame (2 columns and one beam on top) 20 meters high! and there should be a wall 3 meters high connecting these 2 columns together! I need to find the optimum height of the wall from the ground that makes the lateral deflection of the frame minimum! What I do is I draw a rectangular sketch and define V1 in dimension the distance from bottom of the rectangular to the ground and make it a parameter. then I draw a suface inside this rectangular. But when I change V1, only the sketch moves up or down and the surface doesn't move! How can I connect these two together?!!
Thanks!
pink61ir is offline   Reply With Quote
CFX multiphase flow model aximefu CFX 24 February 17, 2018 05:35
Imprint sketch not retained when meshing jcamilleri STAR-CCM+ 17 May 30, 2014 12:30
[DesignModeler] 2D multi-material model darijus ANSYS Meshing & Geometry 0 March 3, 2014 14:34
How to model half channel in Fluent idil FLUENT 0 November 12, 2012 04:17
difference of the laminar and turbulent model duaiduaihu FLUENT 0 August 13, 2010 23:40
