September 11, 2014, 06:42 |
connecting sketch and model!
Jon
Hi everyone,
I have a weird question! I have a 2d frame (2 columns and one beam on top) 20 meters high! and there should be a wall 3 meters high connecting these 2 columns together! I need to find the optimum height of the wall from the ground that makes the lateral deflection of the frame minimum! What I do is I draw a rectangular sketch and define V1 in dimension the distance from bottom of the rectangular to the ground and make it a parameter. then I draw a suface inside this rectangular. But when I change V1, only the sketch moves up or down and the surface doesn't move! How can I connect these two together?!! Thanks! |
CFX multiphase flow model | aximefu | CFX | 24 | February 17, 2018 05:35 |
Imprint sketch not retained when meshing | jcamilleri | STAR-CCM+ | 17 | May 30, 2014 12:30 |
[DesignModeler] 2D multi-material model | darijus | ANSYS Meshing & Geometry | 0 | March 3, 2014 14:34 |
How to model half channel in Fluent | idil | FLUENT | 0 | November 12, 2012 04:17 |
difference of the laminar and turbulent model | duaiduaihu | FLUENT | 0 | August 13, 2010 23:40 |
