October 19, 2014, 18:30 |
Material property change in Ansys Workbench
Leandro
Rep Power: 11 |
Hello everyone,
i'd need your help with a problem i'm having in a transient analysis in Ansys Workbench. I've made a composite model of 2 different materials and i'd like to change the material property (Young's modulus) of one of them after reaching a max.principal stress of 100 Mpa. I've done everything in the Workbench(model,surface load,time steps etc) and i'd like to add an APDL command,but i don't know how it works exactly.I've read some tutorials and i thought of something like this: /SOLU !Command in the solution department *dim,TIMEA,array,20 !Definition of an array named TIMEA with the dimension 20 *DO,i,1,20 !Since the surface load is divided in 20 load steps,i'd like a sort of counter in the array which would run from load step 1 to 20 IF,STRESS1,2,GT,300 !if the max.principal stress of the second material is greater than 300 Mpa THEN,MPCHG,EX,2,30000 !then the material property(Young's Modulus) of the second material will change to 30000 Mpa at that loadstep *ENDDO SOLVE I don't know if those commands are correct and if i can do it this way? I'd be really gratefull if anyone could help me out? Best regards, Leo |
December 9, 2014, 08:17 |
Mehul Patel - CFD Expert
Rep Power: 12 |
Have you got your transient analysis in Ansys project's solution? |
December 17, 2014, 16:17 |
Leandro
Rep Power: 11 |
thanks for your post,but i've done things differently now |
ANSYS 13 X64 Workbench problem: "Could not connect to local server" | ggc | ANSYS | 38 | October 7, 2018 17:11 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 06:44 |
Ansys workbench 12 and 12.1 | ACER | CFX | 0 | April 29, 2011 21:43 |
Ansys Workbench : Unable to update 3D Model | kh_thakor | ANSYS | 0 | January 22, 2011 04:34 |
how new material which is varible canadd in ansys | Abhishek yadu | CFX | 0 | January 30, 2006 06:48 |
