March 18, 2016, 04:02 |
Simulate the pressure in Static Structural
Ali
Rep Power: 11 |
Hi all, I want to simulate pressure of fluid on the flat plate For effect of pressure on the Deformation, the flow passes through to flat plate, Direction y - Axis that is parallel with plate (Crossing flow in plate heat exchanger).
Now, i setup pressure of fluid in the ansys /Component Y P=500Kpa, Is the correct setting to simulate the fluid pressure in the y-direction? |
pressure structural |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
Hydrostatic pressure - static structural | stokesy | Main CFD Forum | 0 | March 10, 2015 07:24 |
Overshooting static pressure | guns_down | FLUENT | 0 | March 18, 2014 01:19 |
Static pressure problem | Kiat110616 | CFX | 0 | April 12, 2011 13:11 |
How to simulate a static pressure sensor ? | axel cole | Fidelity CFD | 1 | August 22, 2008 20:01 |
