Large Deformation Convergence Failure Analysis |
Hi everybody, I am working in Ansys WB trying to solve a problem encountered during my thesis study and I'd really appreaciate any suggests about this. The problem is the following:
I am doing a static structural analysis, the model attached to this post is just representative of a more complex model, but for what concerns my issue we can focus on its schematic model. Indeed in the whole model I am analyzing the bending behavior of a certain material (I cannot say much more because of a non-disclosure agreement), but anyway under high loading conditions I have a non-convergent analysis due to highly distorted elements. The upper volume, the big one, has a Young modulus of 17GPa, while the lower one has E=30MPa, both are linear isotropic materials. I fixed the upper surface of the upper volume while I applied a linear displacement (just along the vertical direction) on the lower surface of the lower volume, which is from 0 to the full thickness lower volume. I did this because I'd like to know how much I can compress this material in order to have a convergent solution. I've tried different solutions: - Refining the mesh - Reducing the substeps - Applying a Nonlinear Adaptive Region MeshvRefinement ( Large deflection option is set ON while weak springs are set OFF) The problem I had is attached in figure 2. The 2 windows help to see the real deformation of the lower volume, while the upper volume is able to penetrate it. I cannot use a Contact Tool option due to an incompability with the Non linear adaptive mesh refinement. What I'd like to know if: Is there any way to allow big deformation under high load, at least reducing the thichkness of the compressed volume almost to a zero lenght, without occurring such penetration? Or is any possibility to prevent this penetration? Thanks so much for your time. With Regards, Simon Last edited by simonkb24; June 4, 2016 at 09:35. Reason: More accurate information |
convergence failure, large deformations |
Display Modes | |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
[OpenFOAM] could not open file .vtk in paraview | ali_atrian | ParaView | 8 | August 27, 2014 10:31 |
Time step dependence of convergence behavior of steady state simulations in CFX | Chander | Main CFD Forum | 5 | December 23, 2013 05:31 |
Simplefoam phi failure and large mesh's | drthompson | OpenFOAM Running, Solving & CFD | 2 | June 23, 2013 17:56 |
