Home > Forums > General Forums > Structural Mechanics
Adding viscoplastic property
Old   March 9, 2017, 11:24
Default Adding viscoplastic property
vikram92 is on a distinguished road
I am trying to analyse the viscoplastic behavior of Stainless steel in ansys workbench, and i dont know how to define material parameters for anand Viscoplastic model. And I am not sure, which parameters to add on, so that the steel can exhibit the viscoplastic behaviour. I am using ansys 17 workbench.
vikram92 is offline   Reply With Quote
Old   March 21, 2017, 23:32
Rajendra Kumar
rajurastogi is on a distinguished road
In the static/transient structure module, there is an option for "Engineering data". Use this to define the desired properties.
rajurastogi is offline   Reply With Quote
Old   March 22, 2017, 01:45
Thank you for the reply. I am trying to use either perzyna model or pierce model for viscoplasticity. But i cannot find this option in Engineering data. Could you please help me with this finding this? These are available in mechanical ADPL, but I could not find in Ansys workbench.
Thank you.
Old   March 23, 2017, 07:43
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Unfortunately the Perzyna and Peirce model is not directly implemented in Ansys workbench. But as you mentioned it is available in APDL classic.
What you can simply do add the material properties under the geometrical definition with an APDL snippet (command object > rmb on your part > insert > command object).
There you can add the Perzyna model using the apdl command as you do in APDL classic.
C1 = 0.8 ! Hardening param
C2 = 0.1 ! Viscosity param
TB, RATE, matid,1,2,perzyna
TBDATA,,C1,C2
Tblist,all,all
If you need temperature dependent material use the TBTEMP command.
Have fun
Gweher is offline   Reply With Quote
Old   March 23, 2017, 10:36
Thank you so much for the reply :-)
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 08:55
chtMultiRegionSimpleFoam 3D problem Lucie OpenFOAM Pre-Processing 2 June 21, 2016 06:23
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 09:43
Adding a particle property manish mehta FLUENT 0 March 20, 2005 00:28
