April 22, 2019, 10:07 |
spring analysis
kumar Rahul
There is an error occurring in my analysis of spring that "The solver engine was unable to converge on a solution for the nonlinear problem as constrained" .I want to know how to solve this error . The model and the force applied is shown in the attached image.
May 20, 2019, 22:01 |
An Pham
Rep Power: 6 |
It maybe due to Contact between bodies. Please share some picture about Connections between bodies
July 28, 2019, 15:47 |
Gwenael H.
Rep Power: 20 |
With the information provided, I would also look at the contact definition. You could also perform a modal analysis to check if you properly defined the contacts.
conical spring analysis | Dem.Pet | System Analysis | 0 | April 14, 2017 13:23 |
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 14:04 |
analysis elastic Rigid airfoil of attached to the spring | hgh | CFX | 0 | March 28, 2016 03:49 |
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) | Scabbard | OpenFOAM Running, Solving & CFD | 1 | July 22, 2014 04:50 |
Modelling the cross aisle direction of a steel selective rack for model analysis | m8rix | ANSYS | 0 | September 20, 2011 10:28 |
