ANSYS Mechanical APDL Error regarding COMBIN39 element
1 Attachment(s)
I have a problem using ANSYS 19.2 Mechanical APDL. I am trying to create a model using Beam 188 elements and non-linear Spring elements (COMBIN39). The spring elements require a specific force-deflection curve. These curves can be implemented using real constants. I have different real constants for the 1D COMBIN39 Springs. Some of these real constants cause the following error: "The last input displacement for element X must be positive." I don't understand the error because all last input displacements of the real constants are positive. Also the error occurs only for R,3, in my script. I have attached a text-file with the srcipt of a reduced version of my model. I hope I have provided all information to help you understand my problem. Thanking you in anticipation and with kind regards MadBean |
2 Attachment(s)
Hi Florian,
Your input and problem definition are correct. This is a tricky one if you didn't encounter it once before. The problem comes from the Real constant definition. You can only define up to 6 constants (see APDL reference manual > command reference > R) : "Use RMORE command if more than six real constants per set are to be input." This was causing your problem. I've attached the corrected .txt version bellow. Have fun ;) |
