Home > Forums > General Forums > Structural Mechanics
Steel Beam-to-column connection Not Solving - Please Help
Old   May 22, 2019, 01:07
Default Steel Beam-to-column connection Not Solving - Please Help
Swan Pyae
swanp is on a distinguished road
Hi there,
I'm quite new to Ansys but I have to analyse a steel beam-to-column connection using Ansys.
I've been at it for almost a week fixing it but no matter what i do, it doesn't seem to be solving successfully.
I initially used solid bodies but the solver is taking too long so, I'm using midsurface shell bodies for the beam and column. I'm getting an error now that some elements in the bolts are experiencing high distortion. I've attached the archive file and the error I'm getting.
https://drive.google.com/open?id=18u...WSBTI36f242V1F
Any help is appreciated to get some results so, I can write my discussion for my thesis. At the moment, I'm very worried that I won't be able to do it.
swanp is offline   Reply With Quote
Old   July 28, 2019, 16:21
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
According the output you have not a good quality mesh -> check the Nut 8 (also on other parts). In your case the nut is not properly defined. Also the bolt suffers from a H-grid type mesh (leading to bad quality elements on the corners). To generate an O-grid mesh type you should include either a mapped face mesh or split up your geometry.
Depending on your hardware you need to adjust the number of cores you allocate for the simulation (within workbench or inside mechanical under tools > solve options).
Have fun
Gweher is offline   Reply With Quote
Trackbacks are On
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 05:07
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 9 September 4, 2015 07:31
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
