Home > Forums > General Forums > Structural Mechanics
pressure deformation linear relationship in a vessel
Old   February 4, 2020, 07:35
Default pressure deformation linear relationship in a vessel
Richardpluff
CRI_CFD is on a distinguished road
Send a message via AIM to CRI_CFD Send a message via Yahoo to CRI_CFD Send a message via Skype™ to CRI_CFD
I have a question regarding pressure vessels.
I obtained the deformation of a vessel for a given internal pressure (in fact I have to consider plasticity of the material, I used multilinear kinematic hardening)
If I use a lower internal pressure, can I establish any kind of linear relation between pressure and deformation based on my previous computation?
I guess that this has no sense in my case. But let us imagine a situation of a linear elastic analysis (Hook's law). If I compute stress for a given load (let's say a pressure of 500 bar) and later I do the same with another pressure (for example 250 bar), then I will be able to obtain a linear relation between pressure and stress in my structure, and the same applies with deformation, isn't it?
Thanks in advance
CRI_CFD is offline   Reply With Quote
Old   February 19, 2020, 07:38
Erik
evcelica is on a distinguished road
If you are using linear material properties, and linear geometry (Large deformation set to off) then everything will be linear.
evcelica is offline   Reply With Quote
How is total pressure calculated? looee CFX 15 October 30, 2019 08:14
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 15:17
pisoFOAM (LES) - internal pipe flow - convergence gu1 OpenFOAM Running, Solving & CFD 0 January 11, 2018 16:39
dynamic mesh: Wall deformation leading to pressure wave in 2D flow channel drifter77 Fluent UDF and Scheme Programming 0 May 8, 2013 09:32
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
