Dynamic Explicit Impact Simulation and comparing with homogenized effective propertie
3 Attachment(s)
I am doing a simulation of a ball striking a plate that has a lattice structure within it. (See Plate.jpeg) The results are shown in (Result.jpg) I Then took a unit cell and brought it into ANSYS material designer to obtain the effective properties. These will give me the young's modulus (E1, E2, E3), shear modulus (G12, G13, G23) and 3 poison's ratio. However, when I used these effective properties, my simulation result for the homogenized structure is vastly different. (see homogenize_result.Jpg) Is this because homogenization only gives the effective elastic properties and not the plastic properties? *I used the same plastic properties for the homogenized simulation as I did for the actual lattice impact simulation. Thanks in advance! |
Thanks for replying karachun!
Just to clarify, thus means that homogenization will be quite useless for my scenario where i am looking into the possibility of plastuc deformation at different speeds? The contact that i had for the ball and plate was tangential contact with penalty of 0.3 and normal contact at default values. Thanks! |
