Home > Forums > General Forums > Structural Mechanics
Dynamic Explicit Impact Simulation and comparing with homogenized effective propertie
Old   February 9, 2020, 11:19
Default Dynamic Explicit Impact Simulation and comparing with homogenized effective propertie
Jwes is on a distinguished road
I am doing a simulation of a ball striking a plate that has a lattice structure within it. (See Plate.jpeg)
The results are shown in (Result.jpg)
I Then took a unit cell and brought it into ANSYS material designer to obtain the effective properties. These will give me the young's modulus (E1, E2, E3), shear modulus (G12, G13, G23) and 3 poison's ratio.
However, when I used these effective properties, my simulation result for the homogenized structure is vastly different. (see homogenize_result.Jpg)
Is this because homogenization only gives the effective elastic properties and not the plastic properties?
*I used the same plastic properties for the homogenized simulation as I did for the actual lattice impact simulation.
Thanks in advance!
Jwes is offline   Reply With Quote
Old   February 10, 2020, 08:01
karachun's Avatar
karachun is on a distinguished road
Yep, you absolutely right. Look like your lattice collapsing is highly nonlinear process because of contact.
karachun is offline   Reply With Quote
Old   February 10, 2020, 08:09
Thanks for replying karachun!
Just to clarify, thus means that homogenization will be quite useless for my scenario where i am looking into the possibility of plastuc deformation at different speeds?
The contact that i had for the ball and plate was tangential contact with penalty of 0.3 and normal contact at default values.
Thanks!
Old   February 10, 2020, 14:55
karachun's Avatar
Yes, homogenous assumption is too coarse.
