February 14, 2020, 10:43 |
Frictional Connections Error, not converging
Siddhesh Patil
Rep Power: 6 |
Below attached geometry is my problem, i am trying to perform in static structural. I have given -500 N on 1/3rd of the length (i.e 5 th block) and connections are frictional with 0.65 frictional coefficient and 2 base faces fixed. Pivot error will and there will be suggestion of using newton raphson unsymmetric.
It works with bonded connection. Please refer the images attached and please help. |
February 16, 2020, 22:34 |
Siddhesh Patil
Rep Power: 6 |
Please help
February 19, 2020, 14:02 |
Erik
Rep Power: 23 |
Maybe add gravity beforehand, on the first load step, then add your force in the second load step. You push that one block down away from the block on its right, then everything to the right of that block is floating in free space with zero constraints.
I'm guessing if you pushed that pluck radially inwards everything would work, but you are pushing it away from everything on the right. |
Eulerian Modeling: Frictional Viscosity Help | meangreen | FLUENT | 1 | January 25, 2018 15:13 |
Calculating frictional losses in cd nozzle | DA6righthand | Main CFD Forum | 3 | June 8, 2017 19:23 |
Can't Update FLuent Setup with active Connections in Mesh | dulka90 | FLUENT | 8 | December 9, 2013 11:36 |
Average frictional stress on surface weighted by elements area (Ansys Workbench Mech) | Giulio89 | Structural Mechanics | 0 | July 8, 2013 09:44 |
GGI (General Grid Interface) Connections | feixiangniao | CFX | 4 | January 14, 2010 19:51 |
