March 5, 2020, 15:46 |
Hydrostatic Force on a Surface
Eric Peters
I have a, hopefully simple, question.
I have a silo that holds feed for cattle. It is a cube 10'x10'x10' and has a funnel at the bottom that goes from 10'x10' to 1'x1' over 7' (measures from the 10x10 to the 10x10 not along it's height) The question is how much force is on the inside of the funnel part? We need to replace the funnel and move from the current metal to a plastic so we can't just replace the material with what it used to be. Constants Specific Weight = 1.275 Density of feed = 53.34 lbs. per cubic foot Total Height of feed bin = 15' I came up with 7.08 PSI ... Which doesn't seem accurate to me. |
March 6, 2020, 02:58 |
Rep Power: 11 |
When you work with bulk materials things become more complicate due to internal friction. Result may highly depend from material properties. Check EN 1991-4 Eurocode 1: Actions on structures - Part 4: Silos and tanks or similar design code, valid in your country.
https://www.phd.eng.br/wp-content/up...991.4.2006.pdf |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
How to separate hydrostatic force from hydrodynamic force | rjm1982 | FLUENT | 1 | February 25, 2018 23:03 |
Force surface goal on deactivated component | native | FloEFD, FloWorks & FloTHERM | 3 | January 20, 2017 03:26 |
Access the surface tension force at a patch | michielm | OpenFOAM Programming & Development | 1 | December 13, 2013 03:50 |
