March 22, 2020, 14:40 |
Contact element type 0 error
Rep Power: 8 |
Hi everybody,
I'm having trouble with structural mechanical solutions for my biomedical model. I need to decrease mesh size because at the previously tested one the solution does not converge. However, when I decrease it the analysis stops in the early phase outputting the following error: "Contact element type 0 used for general contact surface defined by section ID 0 is also associated with other pair based contact element. This pattern is not supported. Please verify the model." I already tried looking for it around but didn't find anything helpful. Here attached you will find the whole solver output. Hope somebody could help me, this is a pretty annoying trouble. :\ |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
