May 16, 2020, 21:24 |
Import Material from Solidwork to Ansys
Sanjay
Rep Power: 6 |
Dear Friends,
I would like to import the material properties used in SolidWorks to Ansys. My Ansys version is 18.1 and I use the following step in the link(https://www.padtinc.com/blog/importi...nical-finally/). But I couldn't able to see the CAD Material Library in the engineering data. The last option for me to write the entire properties from the solid-work to Ansys. Please assist Thanks |
May 17, 2020, 06:39 |
Stuart
Rep Power: 25 |
Are you importing a native SolidWorks file (e.g. *.sldprt) or neutral file format (e.g. parasolid) into ANSYS? Perhaps it requires the SolidWorks Geometry Interface licence from ANSYS. Neither of these is mentioned in your hyperlink.
May 17, 2020, 15:43 |
Sanjay
Rep Power: 6 |
I am using the parasolid, how can I know that I have Geometry Interface License, I have enclosed the geometry properties, I click the material properties still I cant see the CAD Library in the Ansys Engineering Data
May 18, 2020, 02:09 |
Stuart
Rep Power: 25 |
My guess is that using a neutral file format such as parasolid is the problem. Try importing a native SolidWorks file format, you will see the red SolidWorks icon next to Geometry in the ANSYS System. Have a look at the CAD Configuration Manager or Client ANSYSINC_ADMIN Utility programs.
May 19, 2020, 07:40 |
#5 | |
Sanjay
Rep Power: 6 |
I tried to look at the CAD configuration Manager and I couldn't able to find the Geometry Interface and even the box on the solid work is not clicked. I don't have admin control on this. Do you think I can ask to get the interface geometry or ask an admin to click the solid work in Ansys CAD Configuration? |
May 20, 2020, 02:08 |
Stuart
Rep Power: 25 |
Try using a native SolidWorks file format, it could be that simple.
May 26, 2020, 13:46 |
Sanjay
Rep Power: 6 |
It didn't uploaded the solidwork native extension, generally, I always do it .Iges, or .step or .xt parasolid. The aforementioned extension can upload the geom but not the material properties. I am looking for SS316. Do you have any other suggestion
May 27, 2020, 04:00 |
Stuart
Rep Power: 25 |
If you are only looking at SS316 then just create that material in Engineering Data rather than trying to have the data past across via the CAD file.
In alot of situations it is just easier to do things manually. As more time is wasted trying to get the clever option to work. If you are unable to load into ANSYS the SolidWorks native file formats (part or assembly files) then I assume that youu have a licence problem. Are you using a commerical licences but you do not have the SolidWorks Geometry Interface licence. If you are using the ANSYS Student version then that appears only to load in neutral CAD file formats (https://www.ansys.com/academic/free-student-products). As well as SpaceClaim files. |
Display Modes | |
Material definition in ANSYS CFX | vishu343 | CFX | 4 | April 25, 2017 03:22 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
How I could import Ansys mesh into CFX? | mahdi57 | ANSYS Meshing & Geometry | 8 | August 9, 2013 04:49 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
