How to export mesh from AcuSolve/AcuConsole to Hypermesh/Hyperwork ?
anyone has tried to export a mesh from Acuconsole to hypermesh ?
I've built a model in AcuConsole and completed the mesh operation and I'd like to use the same mesh as input into Hypermesh. I've managed to export the MESH.DIR but this file does not seems can be imported to hypermesh/hyperwork. I could not manage to find any tutorials about this as well. pls help ! |
I have exported ".h3d" results from AcuSolve and then imported to SimLab.
then I've exported solver deck ".fem" and then open it through hypermesh. I have applied all constraints and forces required for the model and then I've run the simulation but I've found an error : *** WARNING # 1284 No SPC or SUPORT1 data specified for static SUBCASE 1. Make sure the model is constrained otherwise. *** ERROR 13: Element, 1 is repeated in the input data. *** ERROR 13: Element, 2 is repeated in the input data. *** ERROR 13: Element, 3 is repeated in the input data. *** ERROR 13: Element, 4 is repeated in the input data. *** ERROR 13: Element, 5 is repeated in the input data. *** ERROR 13: Element, 6 is repeated in the input data. *** ERROR 13: Element, 7 is repeated in the input data. *** ERROR 13: Element, 8 is repeated in the input data. *** ERROR 13: Element, 9 is repeated in the input data. *** ERROR 13: Element, 10 is repeated in the input data. *** ERROR 13: Element, 11 is repeated in the input data. *** ERROR 13: Element, 12 is repeated in the input data. *** ERROR 13: Element, 13 is repeated in the input data. *** ERROR 13: Element, 14 is repeated in the input data. *** ERROR 13: Element, 15 is repeated in the input data. *** ERROR # 1938 *** Element has repeat IDs 77963 time(s). is this due to wrong importing/exporting steps that I've done ? if yes, how would this work ? |
error messages from the .OUT file as per below:
*** WARNING # 1284 No SPC or SUPORT1 data specified for static SUBCASE 1. Make sure the model is constrained otherwise. *** ERROR 13: Element, 1 is repeated in the input data. *** ERROR 13: Element, 2 is repeated in the input data. *** ERROR 13: Element, 3 is repeated in the input data. *** ERROR 13: Element, 4 is repeated in the input data. *** ERROR 13: Element, 5 is repeated in the input data. *** ERROR 13: Element, 6 is repeated in the input data. *** ERROR 13: Element, 7 is repeated in the input data. *** ERROR 13: Element, 8 is repeated in the input data. *** ERROR 13: Element, 9 is repeated in the input data. *** ERROR 13: Element, 10 is repeated in the input data. *** ERROR 13: Element, 11 is repeated in the input data. *** ERROR 13: Element, 12 is repeated in the input data. *** ERROR 13: Element, 13 is repeated in the input data. *** ERROR 13: Element, 14 is repeated in the input data. *** ERROR 13: Element, 15 is repeated in the input data. *** ERROR # 1938 *** Element has repeat IDs 77963 time(s). |
