Home > Forums > General Forums > Structural Mechanics
I need help for compression test for my complex imported shape
Old   July 20, 2022, 14:25
Post I need help for compression test for my complex imported shape
Atalay Oztuna
AtaIT is on a distinguished road
Hello, I have been struggling to do a compress test for my imported object.
Here is my setup;
I have created 2 discrate ridig shell planar planes for top and bottom. My part is meshed in Tet-quadratic-hybrid form in abaqus.
I have created geometries and surfaces for my 3 part.
Since my object mesh is already done and it is a complex shape I did element set and mesh surface.
I created 2 contraints with using node function which means only used the sets I created between master(My object) slave(two planar surface)
I created 1 interaction between surfaces and linked them as:
Element(object)-Element(object)
Element(object)-Top
Element(object)-Bottom
And I gave load and velocity from top RP point and gave Encastre state for bottom RP point.
At the end my job gave me an error like this;
Can you tell me which part I am doing wrong? I have been working on this for 2 weeks and same result all the time.
Thank you
AtaIT is offline   Reply With Quote
[ICEM] Meshing of complex shape Far ANSYS Meshing & Geometry 14 January 3, 2013 13:36
[GAMBIT] Meshing Complex Wing Shape racerdude777 ANSYS Meshing & Geometry 1 December 16, 2010 09:31
problem when running icoFoam on a complex shape flow field wendywu OpenFOAM 1 May 20, 2009 23:40
Check cases for turbulance heat transfer on a complex shape Mehdi Main CFD Forum 3 June 1, 2000 22:36
complex geometery as a test case for laminar flow code Morteza Marivani Main CFD Forum 1 December 7, 1999 04:33
