Abaqus python scripting
I want to extract history output of interaction contact force using a python script in abaqus. I was trying to use an example code as below: [I]"import odbAccess import csv odb_path = 'Job1.odb' set_name = 'ASSEMBLY_S_SET-44_CNS_/ASSEMBLY_M_SURF-10' # Name of the set containing the contact region output_name = 'CFT1' # Name of the contact force output variable # Open the ODB file odb = odbAccess.openOdb(odb_path) # Get the output object step = odb.steps.values()[0] output = step.historyRegions[set_name].historyOutputs[output_name] # Get the data for the output variable data = output.data # Export the data to a CSV file with open('contact_force.csv', 'w', newline='') as csvfile: writer = csv.writer(csvfile) writer.writerow(['Time', 'Contact Force']) for i in range(len(data)): writer.writerow([data[i][0], data[1]]) # Close the ODB file odb.close()" The set name for the interaction I obtained from abaqus GUI. It appears I am making some mistake. I get 'Key word error for the setname'. Kindly assist. Ibrahim |
