Home > Forums > General Forums > Structural Mechanics
Rigid body simulation of wheel
Old   March 11, 2025, 12:31
Smile Rigid body simulation of wheel
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hi All,
I am trying to simulate the wheel rolling on the surface using Ansys Rigid Body Dynamica (RBD), I have defined the frictionless contact between wheel and the ground and revolute joint between the wheel center and the hub and also defined the gravity in a downward direction. From the solution results I have observed that the wheel in not rolling on the ground insted it is sliding and in RBM there is no option to define the frictional contact under contacts, the other option available is forced sliding.
Can some one please help me to resolve this issue.
Regards,
Sunil
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   March 17, 2025, 23:00
ryrose is on a distinguished road
Ansys RBD lacks frictional contact. Try applying torque, using forced sliding with velocity constraints, or switching to flexible dynamics for rolling motion.
brain lines
ryrose is offline   Reply With Quote
Old   March 18, 2025, 08:49
sunilpatil's Avatar
sunil
Hi ryrose,
Thanks for your reply. The actual problem I am trying to solve is related to cart which has four swivel caster wheels. Will be applying the force on the top handle of the cart to generate the motion. I cant apply the torque to the wheel since it should be the resutant of applied force.
Can you please tell more about the forced sliding with velocity constraints, the other one with flexible dynamics I will explore.
Regards,
Sunil
ansys, rbm, rolling wheel
Regarding the simulation of thermal wheel heat recovery system Amanpreet Main CFD Forum 0 February 25, 2024 09:30
Rigid body in creeping flow - COMSOL MultiPhy CFD Freelancers 1 June 8, 2017 01:38
Rigid body simulation SHIKHA BHUYAN CFX 4 October 15, 2014 00:13
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 11:24
force convergence problems in CFX 6DOF rigid body solver ajay_ks CFX 8 March 25, 2013 04:02
