[Sponsors] | |||||
Muli material thermal expansion in solids4foam |
Rep Power: 0 ![]() |
I am trying to simulate two hollow pipes, that touch at 1 face, under the influence of a constant temperature field, for a designated amout of time. I would like to achieve a transient result, where I can observe the expansion the pipes experience. Main concern is two pipes are made out of different materials. For example steel and aluminum. The Question is: In solids4foam it is possible to define the mechanical propeties for two different materials and assign them to geometries. However I am not able to figure out, how to assign different thermal properties for different materials.
If you have a solution for it I would be glad to hear. With kind regards |
Samo
Yes, in solids4foam, you can give each pipe its own thermal properties (like thermal conductivity and expansion) — even if they are made of different materials like steel and aluminum.
To do this:): Make sure each pipe is a separate solid region (like "pipe1" and "pipe2"). In each region’s folder (constant/pipe1/ and constant/pipe2/), add a file called thermophysicalProperties. In that file, you can set different thermal values for each material. Just like you set different mechanical properties, you do the same for thermal ones — but in the right folder for each pipe ;). |
| Tags |
| openfaom, solids4foam, thermal analysis |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
| Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
| Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
| Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
| Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
