Home > Forums > Software User Forums > SU2 > SU2 Installation
Compile Error on Fedora, g++, no CGNS, no Metis
Old   August 27, 2013, 21:10
Default Compile Error on Fedora, g++, no CGNS, no Metis
Josh
jstults is on a distinguished road
Here's what I did:
git clone https://github.com/su2code/SU2
Then
./configure
make
No errors reported on the configure, but I get this error on the compile:
g++ -DPACKAGE_NAME=\"SU\^2\" -DPACKAGE_TARNAME=\"SU\^2\" -DPACKAGE_VERSION=\"2.0.6\" -DPACKAGE_STRING=\"SU\^2\ 2.0.6\" -DPACKAGE_BUGREPORT=\"susquared-dev@lists.stanford.edu\" -DPACKAGE_URL=\"http://su2.stanford.edu\" -DPACKAGE=\"SU\^2\" -DVERSION=\"2.0.6\" -I.    -DNO_CGNS -DNO_METIS -DNO_TECIO -DNO_MPI -MT ../src/libSU2_a-linear_solvers_structure.o -MD -MP -MF ../src/.deps/libSU2_a-linear_solvers_structure.Tpo -c -o ../src/libSU2_a-linear_solvers_structure.o `test -f '../src/linear_solvers_structure.cpp' || echo './'`../src/linear_solvers_structure.cpp
../src/linear_solvers_structure.cpp: In member function ‘long unsigned int CSysSolve::ConjugateGradient(const CSysVector&, CSysVector&, CMatrixVectorProduct&, CPreconditioner&, double, long unsigned int, bool)’:
../src/linear_solvers_structure.cpp:155:11: error: ‘exit’ was not declared in this scope
../src/linear_solvers_structure.cpp: In member function ‘long unsigned int CSysSolve::FGMRES(const CSysVector&, CSysVector&, CMatrixVectorProduct&, CPreconditioner&, double, long unsigned int, bool)’:
../src/linear_solvers_structure.cpp:260:11: error: ‘exit’ was not declared in this scope
../src/linear_solvers_structure.cpp:271:11: error: ‘exit’ was not declared in this scope
../src/linear_solvers_structure.cpp: In member function ‘long unsigned int CSysSolve::BCGSTAB(const CSysVector&, CSysVector&, CMatrixVectorProduct&, CPreconditioner&, double, long unsigned int, bool)’:
../src/linear_solvers_structure.cpp:392:11: error: ‘exit’ was not declared in this scope
make[1]: *** [../src/libSU2_a-linear_solvers_structure.o] Error 1
I successfully compiled / ran version 2.0.2 from the tarball on this system before you guys went to git (thanks for doing that btw).
jstults is offline   Reply With Quote
Old   August 28, 2013, 00:02
Francisco Palacios
fpalacios is on a distinguished road
Thanks for letting us know, and your nice words.
As you know, exit() is a very typical function in C++. But, as far I see, in gcc 4.3 the #include <cstdlib> should be in the code (before we were using #include <iostream>).
I have just updated the git repository. Could you please try again with the new code.
Cheers,
Francisco
Originally Posted by jstults View Post
Here's what I did:
Then
./configure
make
fpalacios is offline   Reply With Quote
Old   August 28, 2013, 20:31
Josh
Works a treat; thanks!
compiling with MPI, METIS, CGNS on iMac monkeytron SU2 Installation 5 June 5, 2013 08:06
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
Compile OpenFOAM on Fedora 8 asaha OpenFOAM Installation 1 August 25, 2008 11:41
How to conert cgns in to node array for Metis? John Main CFD Forum 15 November 14, 2006 08:33
How to conevrt cgns file in node array for metis? John CFX 0 November 12, 2006 22:54
