September 16, 2014, 16:47 |
how to locate mpi.h using ./configure
Sean (J.X.) Shi
Rep Power: 13 |
I am working on a server.
I found mpicxx and mpi.h are not in standard library. When I use /configure --prefix=/home/user/SU2 --with-MPI=/usr/mpi/bin/mpicxx then make, it returns ../src/../include/config_structure.hpp:27:17: error: mpi.h: No such file or directory The mpi.h is located in /usr/mpi/include. How to solve this problem? Thank you in advance. |
September 22, 2014, 08:18 |
Khiem Pham
Rep Power: 12 |
Perhap, you may find folder, which contain mpicxx. In my case it locate in usr/bin.
Good luck |
September 22, 2014, 09:47 |
Jeffrey van Oostrom
Rep Power: 12 |
I have had the same issue on my machine, which had MPI pre-installed. I suggest you simply rebuild OpenMPI or any other on your machine/server, such that the MPI.H file is in the correct folder.
Jeffrey |
How to locate all the edge node by UDF? | hadesmajesty | Fluent UDF and Scheme Programming | 1 | August 7, 2013 03:52 |
Tutorial 8 - Unable to locate import executable | Kambusha | CFX | 0 | April 10, 2009 07:58 |
a cone injection,please help me!! | satum | FLUENT | 0 | July 2, 2008 02:38 |
How to locate the place of injector ? | haixiao | Siemens | 2 | April 6, 2006 20:55 |
CCM+: unable to locate Java VM | Amod Kumar | Siemens | 0 | March 22, 2005 00:42 |
