Configure: Checking libjson.a (SU2 4.0.1)
Hello there,
I was configuring the SU2 4.0.1 with Jsoncpp flags and find out that configure file checks for libjson.a. However, my Jsoncpp library is actually libjsoncpp.a. I have edited the configure file to check for libjsoncpp.a instead and everything went fine in installation. I used Jsoncpp 0.10.5. I also already used 0.5.0 version which its library was libjson_linux-gcc-4.8_libmt.a, based my OS. By editing the configure file, the installation went fine for both Jsoncpp versions. The running OS is Ubuntu 14.04 for the knowledge. Did you guys mention libjeson.a for being checked in the configure intentionally or this is happened because of using different Jsoncpp builds or difference between the OS? I think there is a difference in general between libjson and libjsoncpp. I also noticed the configure also checks for libmutation++.dylib which is different with extension of Ubuntu users's dynamic library, 'so'. I also changed the check for libmutation++.so in the configure file. There is a difference between .dylib and .so in OSX I guess, but I think this is not the case for Linux users. Bests, Payam |
PDP |
