October 16, 2015, 03:38 |
SU2 Installation on Windows 32 bit
I am using Windows 7 (32 bit) and decided to get started using SU2. I've registered in SU2 download page and I hadn't found a binary version of SU2 for Windows 32 bit except SU2_EDU (the screenshot is attached). Is SU2_EDU is enough and have same instruction for following all SU2 tutorial? Can you provide me the SU2 download link for Windows 32 bit? Then because I am a novice in CFD, can you give me advice the step to practicing the CFD theory using SU2? Because I slightly confused when reading SU2 tutorial in Github. Thanks, Saaddin |
October 30, 2015, 14:31 |
JAE HWAN CHOI
Rep Power: 10 |
We only support 64 bit binary version with the current release, sorry. Best, Jae hwan Choi |
May 6, 2016, 09:09 |
SU2 Installation windows 7 32 bit
Nazi
Rep Power: 9 |
I register in http://su2.stanford.edu and download the SU2-4.1.1 for windows 7 (32-bit). I found some guidance for installation in this link : https://github.com/su2code/SU2/wiki/...s-Installation. However, I can't install the SU2_CFD. Is there anybody have any information about this issue? |
May 6, 2016, 17:03 |
JAE HWAN CHOI
Rep Power: 10 |
Would you please specify the issue? Is it related to the installation wizard? Or are you facing the problem with running the "SU2_CFD" executable? Best, Jae hwan Choi |
Compiling UDF in windows 64 bit | amir2920 | Fluent UDF and Scheme Programming | 1 | April 4, 2019 12:00 |
SU2 windows setup options | esco_rep | SU2 Installation | 3 | August 20, 2015 19:56 |
a question about parallel in windows 7 | 454514566@qq.com | SU2 | 8 | June 12, 2014 03:46 |
OpenFOAM Installation on Debian-testing 64 bit | Afacci | OpenFOAM Installation | 4 | June 30, 2012 17:54 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
