SU2 Installation on Windows 32 bit
1 Attachment(s)
I am using Windows 7 (32 bit) and decided to get started using SU2. I've registered in SU2 download page and I hadn't found a binary version of SU2 for Windows 32 bit except SU2_EDU (the screenshot is attached). Is SU2_EDU is enough and have same instruction for following all SU2 tutorial? Can you provide me the SU2 download link for Windows 32 bit? Then because I am a novice in CFD, can you give me advice the step to practicing the CFD theory using SU2? Because I slightly confused when reading SU2 tutorial in Github. Thanks, Saaddin |
We only support 64 bit binary version with the current release, sorry. Best, Jae hwan Choi |
SU2 Installation windows 7 32 bit
I register in http://su2.stanford.edu and download the SU2-4.1.1 for windows 7 (32-bit). I found some guidance for installation in this link : https://github.com/su2code/SU2/wiki/...s-Installation. However, I can't install the SU2_CFD. Is there anybody have any information about this issue? |
Would you please specify the issue? Is it related to the installation wizard? Or are you facing the problem with running the "SU2_CFD" executable? Best, Jae hwan Choi |
