March 14, 2013, 10:59 |
error while running SU2 in parallel
Rep Power: 13 |
Hi
I installed SU2 from sourcecode on the cluster but when I am trying to run it it generates following error file & doesn't generate any output. Could you guys please have a look at it & see if there is something that needs to be fixed at my end. I used gcc compiler & mvapich2 for compiling my code. code was compiled with arnings but no errors. Thanks a lot for ur help Abhii |
March 24, 2013, 00:19 |
#2 | |
Francisco Palacios
Rep Power: 15 |
http://adl.stanford.edu/docs/display...on+from+Source Best, Francisco |
March 24, 2013, 11:08 |
Rep Power: 13 |
yes, I created relevant environment variables in my bashrc
Thanks Abhii |
March 24, 2013, 12:32 |
Francisco Palacios
Rep Power: 15 |
It could be a Python issue, could you please run the code manually?
./SU2_CFD {name of the config file} Does it work? What's the version of Python and NumPy that you are using? Cheers, Francisco |
May 29, 2013, 14:58 |
#5 | |
Rep Power: 13 |
Thanks Francisco
I was on other projects for a while.... how ever I have reinstalled SU2& now I when I try to run it it flags following error message Quote:
& I am using following modules for running openmpi/1.4.3-intel python/2.6.7 I would really appreciate if you could let me know as to what is it that needs to be fixed. Thanks again for your help Regards Abhii Last edited by Abhii; May 29, 2013 at 16:52. |
June 5, 2013, 00:19 |
Rep Power: 13 |
comment deleted
June 13, 2017, 01:08 |
jit
Rep Power: 10 |
Hi Abhi,
could you please share how did you sort out your problem. I have faced similar problem in unsteady case. It is not generating any output files either at every iterations or after solution convergence |
parallel installation |
Display Modes | |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 22:33 |
Running mapFields with Parallel Source and Parallel Target | RDanks | OpenFOAM Pre-Processing | 4 | August 2, 2016 06:24 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 09:53 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 04:50 |
Running in parallel crashed | zhajingjing | OpenFOAM | 4 | September 15, 2010 08:12 |
