May 28, 2017, 13:16 |
AD build problem SU2-5.0.0
Rep Power: 8 |
I'm trying to compile su2 with AD support. When I use this command: "export CXXFLAGS="-O3 -Wall" && ./preconfigure.py --enable-autodiff --enable-mpi --prefix=$SU2_INSTALLPATH" I get the following message: Checking the status of submodules ================================================== =================== Found an old or unspecified version of CoDiPack in externals/codi. Use -u to reset module. Could you please help me resolve the problem? Thanks |
May 29, 2017, 16:00 |
#2 | |
Rep Power: 10 |
Try removing codi directory inside externals and run preconfigure again. It must download it for you and solve the isuue. |
May 29, 2017, 16:55 |
Rep Power: 8 |
October 13, 2017, 10:11 |
Rep Power: 9 |
I encounter the same problem. After remmoving the codi directory and running preconfigure again, I get the following message:
Checking the status of submodules ================================================== =================== Initializing CoDiPack '2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13' ================================================== =================== Downloading module from https://github.com/scicompkl/CoDiPack Extracting archive ... Extraction of module CoDiPack failed. See preconf.err for more information. So I open the "preconf.err", it shows: --2017-10-13 22:00:57-- https://github.com/scicompkl/CoDiPac...9244484f13.zip 正在解析主机 github.com (github.com)... 192.30.255.113, 192.30.255.112 正在连接 github.com (github.com)|192.30.255.113|:443... 已连接。 已发出 HTTP 请求,正在等待回应... 302 Found 位置:https://codeload.github.com/SciCompK...6dc69244484f13 [跟随至新的 URL] --2017-10-13 22:01:01-- https://codeload.github.com/SciCompK...6dc69244484f13 正在解析主机 codeload.github.com (codeload.github.com)... 192.30.255.121, 192.30.255.120 正在连接 codeload.github.com (codeload.github.com)|192.30.255.121|:443... 已连接。 已发出 HTTP 请求,正在等待回应... 200 OK 长度: 未指定 [application/zip] ///length: not specified 正在保存至: “2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13.zip” 0K .......... .......... .......... .......... .......... 75.6K 50K .......... .......... .......... .......... .......... 144K 100K .......... .......... .......... .......... .......... 8.03M 150K .......... .......... .......... .......... .......... 140K 200K .......... .......... .......... .......... ...... 141K=1.7s 缺少“Last-modified”文件头 -- 关闭时间戳标记。 //// translate in English: lack the file header" Last-modified " 2017-10-13 22:01:04 (145 KB/s) - “2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13.zip” 已保存 [252908] /bin/sh: 1: unzip: not found I have translate some main sentences. I don't know how to solve this problem, could you please give me some advice? Thanks. Last edited by Kaizhi Ding; October 13, 2017 at 10:29. Reason: translate to some words to English |
October 13, 2017, 16:08 |
Tim Albring
Rep Power: 10 |
Hi Kaizhi,
it looks like unzip is not installed on your machine. Try to install it with the package manager of your distribution. Otherwise, if you want to use your preferred unpacking tool try the following steps: - Download the zip at "https://github.com/scicompkl/CoDiPack/archive/2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13.zip" - Extract the archive to externals/codi - Execute command 'touch externals/codi/2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13' - Run preconfigure.py again Tim
Developer Director @ SU2 Foundation Get involved:
October 14, 2017, 03:10 |
#6 | |
Rep Power: 9 |
November 30, 2017, 00:16 |
#7 | |
Tim Jim
Rep Power: 8 |
Initializing CoDiPack '2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13' ===================================================================== Downloading module from https://github.com/scicompkl/CoDiPack Extracting archive ... Extraction of module CoDiPack failed. See preconf.err for more information. Code:
--2017-11-30 14:13:17-- https://github.com/scicompkl/CoDiPack/archive/2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13.zip Resolving github.com... 192.30.255.113, 192.30.255.112 Connecting to github.com|192.30.255.113|:443... connected. HTTP request sent, awaiting response... 302 Found Location: https://codeload.github.com/SciCompKL/CoDiPack/zip/2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13 [following] --2017-11-30 14:13:18-- https://codeload.github.com/SciCompKL/CoDiPack/zip/2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13 Resolving codeload.github.com... 192.30.255.121, 192.30.255.120 Connecting to codeload.github.com|192.30.255.121|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 252908 (247K) [application/zip] Last-modified header missing -- time-stamps turned off. --2017-11-30 14:13:19-- https://codeload.github.com/SciCompKL/CoDiPack/zip/2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13 Reusing existing connection to codeload.github.com:443. HTTP request sent, awaiting response... 200 OK Length: 252908 (247K) [application/zip] Saving to: `2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13' 0K .......... .......... .......... .......... .......... 20% 131K 2s 50K .......... .......... .......... .......... .......... 40% 257K 1s 100K .......... .......... .......... .......... .......... 60% 256K 0s 150K .......... .......... .......... .......... .......... 80% 262K 0s 200K .......... .......... .......... .......... ...... 100% 7.85M=1.0s 2017-11-30 14:13:20 (255 KB/s) - `2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13' saved [252908/252908] unzip: cannot find or open 2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13.zip, 2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13.zip.zip or 2ec7cccf3ccd4b052f9d4ef95d6dc69244484f13.zip.ZIP. |
November 30, 2017, 04:03 |
#8 | |
Tim Albring
Rep Power: 10 |
Hi Tim,
just follow the steps I posted also above: Quote:
December 1, 2017, 02:28 |
#9 |
Tim Jim
Rep Power: 8 |
Hi, thanks for the post, it's now producing a similar problem with AdjointMPI...
Checking the status of submodules ===================================================================== Found correct version of CoDiPack in externals/codi. Found an old or unspecified version of AdjointMPI in externals/adjointmpi. Use -u to reset module. Many thanks. |
December 1, 2017, 02:47 |
#10 |
Tim Jim
Rep Power: 8 |
I had a dig around preconfigure.py and I did the same steps as above but grabbing the file from `https://github.com/michel2323/AdjointMPI` and touch on `31b2267c3a55a391a37d830369f2e0dba09008d1`.
I'm wondering if something strange is happening, because now it seems to be having trouble finding configure? Code:
Checking the status of submodules ===================================================================== Found correct version of CoDiPack in externals/codi. Found correct version of AdjointMPI in externals/adjointmpi. Configuring and building AdjointMPI in externals/adjointmpi ===================================================================== Command: ./configure --prefix=/home/FIa/FIa164/programs/su2/SU2-5.0.0_src/externals/adjointmpi --with-mpicc=/home/FIa/FIa164/programs/openmpi/openmpi-3.0.0/bin/mpicc && make clean && make There was an error while running command './configure --prefix=/home/FIa/FIa164/programs/su2/SU2-5.0.0_src/externals/adjointmpi --with-mpicc=/home/FIa/FIa164/programs/openmpi/openmpi-3.0.0/bin/mpicc && make clean && make'. === Error Log === /bin/sh: ./configure: No such file or directory |
December 1, 2017, 16:52 |
#11 |
Tim Albring
Rep Power: 10 |
Can you check whether the file externals/adjointmpi/configure actually exists ? Maybe the archive was not properly extracted ..
December 2, 2017, 01:53 |
#12 |
Tim Jim
Rep Power: 8 |
December 2, 2017, 14:37 |
#13 |
Tim Albring
Rep Power: 10 |
Ok you downloaded the wrong version (i.e. commit). Use this link to download the correct one:
https://github.com/michel2323/Adjoin...dba09008d1.zip
December 4, 2017, 02:00 |
#14 | |
Tim Jim
Rep Power: 8 |
While building, I'm coming across a different problem (I'm not sure if I should put this in a new issue?) - do you have any experience installing SU2 with OpenBLAS as the lapack library? After setting the flag --with-LAPACK-include=/home/FIa/FIa164/programs/openblas/OpenBLAS-0.2.20/include I notice that SU2 search in the specified PREFIX/include for liblapacke.a (is this some kind of c lapack library?). The problem is that there is no file named this in the OpenBLAS include folder - should I be renaming/symbolic linking to another file in the include directory? These are the files I have: Code:
FIa164@afispb07:~/programs/openblas/OpenBLAS-0.2.20/include$ ls cblas.h f77blas.h lapacke_config.h lapacke.h lapacke_mangling.h lapacke_utils.h openblas_config.h |
su2 adjoint, su2 install, su2 make error |
Pitching and Plunging problem in SU2 | albinjohny | SU2 Shape Design | 1 | July 5, 2015 01:54 |
OpenFOAM gcc configuration problem | preacher | OpenFOAM Installation | 7 | March 3, 2014 22:44 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
Build problem | Jeff | CFX | 0 | July 31, 2003 13:21 |
CFX4.3 Build problem | cfx4.3 user | CFX | 4 | January 2, 2003 14:18 |
