February 18, 2018, 05:57 |
Error Installing SU2 6.0.0
Ghifari Adam Faza
Rep Power: 9 |
Hi
I'm totally new to SU2 and I encountered this problem when building SU2 from the source. Screenshot from 2018-02-18 17-46-36.jpg I was just following the instructions from github : "To build SU2 from the source code, just open a terminal and run the './configure', 'make', and 'make install' commands in the root directory of the source distribution." But in the './configure' step, the terminal gave me this message: configure: error: cannot find python-config for /usr/bin/python. Could anyone help me? Thanks |
February 24, 2018, 13:42 |
Francisco Palacios
Rep Power: 15 |
February 27, 2018, 10:39 |
python-devel
Aldo Bonfiglioli
Rep Power: 13 |
Installing python-devel on OpenSUSE Thumbleweed solved that issue.
March 8, 2018, 07:09 |
JAMES
Rep Power: 9 |
Hi friends, I also meet this problem. Have you fix it? I install the python-config but still not ok.
March 8, 2018, 09:30 |
#5 | |
Ghifari Adam Faza
Rep Power: 9 |
./configure --with-PYTHON=/path/to/PythonInterpreter. Actually you can take a look at ./configure --help Maybe it could help you. best regards, Ghifari |
February 16, 2019, 01:21 |
#6 | |
Karl Yang
Rep Power: 9 |
Hi, Ghifari, Could you explain a bit more on python interpreter? I'm using a cluster with python preinstalled. I am not sure where to find the path, neither do I have the right to install with yum. Regards Juntao |
March 1, 2019, 08:07 |
#7 | |
Amir Bagheri
Rep Power: 7 |
I believe you can list your loaded environment modules on the cluster and check for your python module. This is achieved by typing "module list" in your terminal window. Once you've identified the python package name, you can run "module show" in conjunction with the python module name to get the library and bin paths. For example "module show python/2.7.14" If python isn't loaded, you can load it first by typing "module avail" and finding the python package you want. Then "module load *module name*". Hope this helps. Amir |
installation, su2, ubuntu 16.04 lts |
SU2 process was terminated by signal '11' | tomp1993 | SU2 Shape Design | 5 | March 1, 2018 04:32 |
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release | fpalacios | SU2 News & Announcements | 1 | April 30, 2014 02:40 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 05:28 |
SU2 suite has moved to GitHub! | fpalacios | SU2 News & Announcements | 0 | August 12, 2013 02:07 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
