February 21, 2020, 13:20 |
Parallel computation on windows 8
serg
Rep Power: 10 |
I googled it but could not find the answer. My problem is, when I use "parallel_computation.py" script, all cores run the whole mesh instead of a partitioned one, and each core performs each iteration (4 cores = 4 identical solution), but if I use mpiexec -n #cores SU2_CFD.exe [config file] instead, It works. I have no problem with that, but for the optimization tutorials, I could not solve the issue and running the optimization cases on a single core is pretty annoying. I followed the steps -which is very straightforward- for a Win machine, I did not compile the code by using cygwin. I have the latest version of SU2, python version is 3.8.1, numpy's is 1.18.1, scipy's is 1.4.1 I have MS-MPI, version is 10.1.12498.18. SU2_RUN, path for MPI and python are set accordingly. Any help is appreciated. Regards. S. |
February 22, 2020, 12:22 |
Pedro Gomes
Rep Power: 13 |
Do you have more than one mpi version in your system?
The optimization script might be calling mpirun instead (not sure what is the default). If you run mpirun -n # SU2_CFD do you get the same problem? |
February 22, 2020, 13:58 |
#3 | |
serg
Rep Power: 10 |
Thank you. |
February 26, 2020, 06:18 |
Pedro Gomes
Rep Power: 13 |
You can define a custom mpi command via environment variable SU2_MPI_COMMAND, this is used in $SU2_RUN/SU2/run/interface.py, if all else fails you can always hack that script.
February 27, 2020, 11:19 |
#5 | |
serg
Rep Power: 10 |
https://github.com/su2code/SU2/issues/559 I am just going over the tutorials, and not changing anything in the config files, yet I can't detect the problem. Do you have any idea? |
The problem when i use parallel computation for mesh deforming. | Hiroaki Sumikawa | OpenFOAM Running, Solving & CFD | 0 | November 20, 2018 02:58 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
Windows 7 parallel calculations | curky | SU2 Installation | 23 | May 14, 2013 02:17 |
problem in the CFX12.1 parallel computation | BalanceChen | ANSYS | 2 | July 7, 2011 10:26 |
about parallel computation | akang | CFX | 5 | June 22, 2005 10:51 |
