Home > Forums > Software User Forums > SU2 > SU2 Installation
Multiple Installations of SU2
Like Tree1Likes
  • 1 Post By bigfootedrockmidget
Old   March 5, 2021, 16:01
Default Multiple Installations of SU2
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello SU2 users,
I wonder if it's possible to install different versions of SU2 on the same machine (in my case I'm using ubuntu 20) and how to do that in case.
Best regards
FlyBob91 is offline   Reply With Quote
Old   March 6, 2021, 05:57
bigfoot
bigfootedrockmidget is on a distinguished road
yes, that is possible. The simplest method is to just install the SU2 binaries inside the local su2 directories, and not install SU2 globally. With meson, you add the option --prefix=/home/flybob/su2_version25. When running, you just use the complete path to the executable, so mpirun -n 1024 /home/flybob/su2_version25/bin/SU2_CFD config.cfg
If you just want to try different feature branches of a git clone, you can simply switch from one branch to the next by using git checkout, e.g. git checkout master, git checkout develop
FlyBob91 likes this.
bigfootedrockmidget is offline   Reply With Quote
Old   March 18, 2021, 03:58
FlyBob91's Avatar
Thank you bigfoot,
is it possible to create an alias so that I can load the environment I need through only just one command. I'm afraid that your solution could, by typing the path, could give me troubles when using advanced features like adjoint shape optimization.
Best regards
Old   March 19, 2021, 19:33
bigfoot
su2 tells you to put 4 export commands in .bashrc, so every time you start a shell, these paths are set. You can also choose NOT to put them in .bashrc and put them in a file, say path2v701, path2v711
and use
$ source pathv701
to load them. Now, when you have loaded pathv701 and want to switch to pathv711, you also need to restore the original PATH with the old SU2 directory, so copy the original path:
$ echo $PATH
/home/flybob91/bin:/home/flybob91/SU2/bin
and copy this path string into to your pathv701, etc. files and put it on the first line as:
export PATH=/home/flybob91/bin
and do the same thing for PYTHONPATH
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 23:38
SU2 example job on multiple nodes creates incorrect result merijn SU2 Installation 0 December 14, 2018 09:58
SU2 for multiple sampling optimization Raj_1 SU2 3 August 6, 2016 15:16
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
