April 4, 2024, 09:31 |
SU2 Installation failed
rks231
Hello guys, I am facing the following issue while installing the SU2; what should I do, I want to use FSI and pywrapper for the python function. Thank you so much in advancd. I follow in the following way;
$ python3.9 -m venv venv $ source venv/bin/activate (venv) $ export MPICC=/opt/intel/oneapi/mpi/2021.6.0/bin/mpicc (venv) $ export MPICXX=/opt/intel/oneapi/mpi/2021.6.0/bin/mpicxx (venv) $ export CC=$MPICC (venv) $ export CXX=$MPICXX (venv) $ pip install --upgrade pip (venv) $ pip install mpi4py Requirement already satisfied: mpi4py in ./venv/lib/python3.9/site-packages (3.1.5) (venv) $ ./meson.py build -Denable-autodiff=true -Denable-directdiff=true -Denable-pywrapper=true -Dcustom-mpi=true Message: Using mpi4py from /data/home/rashmi/local/SU2/venv/lib/python3.9/site-packages/mpi4py/include WARNING: extract_all_objects called without setting recursive keyword argument. Meson currently defaults to non-recursive to maintain backward compatibility but the default will be changed in the future. SU2_PY/pySU2/meson.build:36:2: ERROR: Tried to form an absolute path to a source dir. You should not do that but use relative paths instead. To get include path to any directory relative to the current dir do incdir = include_directories(dirname) After this incdir will contain both the current source dir as well as the corresponding build dir. It can then be used in any subdirectory and Meson will take care of all the busywork to make paths work. Dirname can even be '.' to mark the current directory. Though you should remember that the current source and build directories are always put in the include directories by default so you only need to do include_directories('.') if you intend to use the result in a different subdirectory. |
Installation error with SU2 - Adjoint | cfd-jg | SU2 Installation | 0 | December 18, 2023 06:55 |
SU2 parallel install build from source failed | steadyman | SU2 Installation | 19 | April 25, 2021 16:50 |
[foam-extend.org] 3.2 Installation in Debian 8.5 | jsm | OpenFOAM Installation | 2 | June 19, 2016 10:53 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 15:31 |
DeardorffDiffStress turbulence model | Zuixy | OpenFOAM Running, Solving & CFD | 0 | November 14, 2011 08:44 |
