Problems with ninja command
After downloading the source code of SU2 7.5.1 from github and switching to the 'develop' branch from the 'master' one, I tried to build the 'build' (enabling CoolProp and disabling CGNS support) via the command
./meson.py build -Denable-coolprop=true -Denable-cgns=false This seemed to work. When I run the command to install ./ninja -C build install I get the following error: [497/509] Linking target SU2_GEO/src/SU2_GEO FAILED: SU2_GEO/src/SU2_GEO c++ -o SU2_GEO/src/SU2_GEO SU2_GEO/src/SU2_GEO.p/SU2_GEO.cpp.o -Wl,--as-needed -Wl,--no-undefined -Wl,-O1 -Wl,-rpath,/usr/lib/x86_64-linux-gnu/openmpi/lib -Wl,-rpath-link,/usr/lib/x86_64-linux-gnu/openmpi/lib -Wl,--start-group externals/metis/libmetis.a externals/parmetis/libparmetis.a externals/tecio/teciompisrc/libteciompi.a subprojects/CoolProp/libCoolProp.a Common/src/libSU2Common.a -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi_cxx.so -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi -L/usr/lib/x86_64-linux-gnu/openmpi/lib -L/usr//lib -lmpi -Wl,--end-group /usr/bin/ld: impossibile trovare -lmpi /usr/bin/ld: impossibile trovare -lmpi /usr/bin/ld: impossibile trovare -lmpi /usr/bin/ld: impossibile trovare -lmpi /usr/bin/ld: impossibile trovare -lmpi /usr/bin/ld: impossibile trovare -lmpi /usr/bin/ld: impossibile trovare -lmpi /usr/bin/ld: impossibile trovare -lmpi collect2: error: ld returned 1 exit status [502/509] Compiling C++ object SU2_DEF/src/SU2_DEF.p/drivers_CDiscAdjDeformationDriver.cpp.o ninja: build stopped: subcommand failed. What I tried then was to disable the MPI support and try again with the ninja command. This time I got a different error: [405/411] Linking target SU2_CFD/src/SU2_CFD FAILED: SU2_CFD/src/SU2_CFD c++ -o SU2_CFD/src/SU2_CFD SU2_CFD/src/SU2_CFD.p/SU2_CFD.cpp.o -Wl,--as-needed -Wl,--no-undefined -Wl,-O1 -Wl,--start-group SU2_CFD/src/libSU2core.a externals/tecio/teciosrc/libtecio.a subprojects/CoolProp/libCoolProp.a Common/src/libSU2Common.a -Wl,--end-group -pthread subprojects/CoolProp/libCoolProp.a.p/src_Backends_REFPROP_REFPROPMixtureBackend.cpp.o: nella funzione "getFunctionPointer(char const*, DLLNameManglingStyle)": REFPROPMixtureBackend.cpp:(.text+0xcc4): riferimento non definito a "dlsym" subprojects/CoolProp/libCoolProp.a.p/src_Backends_REFPROP_REFPROPMixtureBackend.cpp.o: nella funzione "load_REFPROP(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)": REFPROPMixtureBackend.cpp:(.text+0x2108): riferimento non definito a "dlopen" REFPROPMixtureBackend.cpp:(.text+0x2561): riferimento non definito a "dlerror" subprojects/CoolProp/libCoolProp.a.p/src_Backends_REFPROP_REFPROPMixtureBackend.cpp.o: nella funzione "unload_REFPROP(std::__cxx11::basic_string<cha r, std::char_traits<char>, std::allocator<char> >&)": REFPROPMixtureBackend.cpp:(.text+0x278c): riferimento non definito a "dlclose" REFPROPMixtureBackend.cpp:(.text+0x27d1): riferimento non definito a "dlerror" collect2: error: ld returned 1 exit status [407/411] Compiling C++ object SU2_DEF/src/SU2_DEF.p/drivers_CDiscAdjDeformationDriver.cpp.o ninja: build stopped: subcommand failed Has anyone faced this problem before or can someone help me to solve it? |
Hi, thanks for your interest in SU2 and CoolProp.
I succeeded the compilation and what I did is the following: 1. download SU2 develop branch $ git clone https://github.com/su2code/SU2.git --branch=develop 2. compile $ ./meson.py build -Denable-coolprop=true -Denable-cgns=false -Dwith-mpi=enabled --prefix=/home/yan/Downloads 3. build $ ./ninja -C build install -j 4 If you encounter some issue with mpi, you can try: $ sudo apt install libopenmpi-dev Good luck. |
Hello Penggege,
I cannot figure out how to install SU2 with coolprop enabled. When using ninja, I get errors like: Code:
Compiling C++ object subprojects/CoolProp/libCoolProp.a.p/src_CPfilepaths.cpp.o I am building with Cmake from Source. SU2 Version is blackbird. Thanks a bunch, Vinz |
it looks like you are missing the fmt package. I think it's called libfmt-dev so you could try installing that with apt-get.
