meson-install problem Mac
Hi I'm trying to install SU2 on my Mac Intel with the latest version of MacOS installed, but it seems to be an error at the end of the compilation, so before installing:
OSError: [Errno 45] Operation not supported: '/home/enricolisena' ERROR: Unhandled python exception This is a Meson bug and should be reported! FAILED: meson-install /usr/local/bin/python3 /Users/enricolisena/Codes/SU2/meson.py install --no-rebuild ninja: build stopped: subcommand failed. Anyone knows how to fix it? Thanks. |
sudo
I had the same problem, try running the meson and ninja commands with sudo
Hi, thanks for your reply.
I actually figure out that it was a problem when copying the path as I was following a guide for Ubuntu so "Users" is "home" for it. After that, everything worked! |
