Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2-Parallel Installation Problems
Old   May 8, 2024, 05:45
Default SU2-Parallel Installation Problems
sntblm
sntblm is on a distinguished road
I'm trying to install SU2-8.0.1 the latest version from source with parallel support. I successfully passed the "./meson.py build" part and added "-Dcustom-mpi=true -Dextra-deps=mpich" part at the end of "./meson.py build" . I also added to my bashrc this line "export PKG_CONFIG_PATH=/home/ub/Desktop/mpich/lib/pkgconfig:$PKG_CONFIG_PATH" to make sure everything is in order. When I try to run this command "./ninja -C build install" I get the error below:
ninja: Entering directory `build'
[1/811] Compiling C object externals/cgns/hdf5/libsu2hdf5.a.p/H5dbg.c.o
FAILED: externals/cgns/hdf5/libsu2hdf5.a.p/H5dbg.c.o
cc -Iexternals/cgns/hdf5/libsu2hdf5.a.p -Iexternals/cgns/hdf5 -I../externals/cgns/hdf5 -fdiagnostics-color=always -std=c99 -O3 -fPIC -Wno-unused-result -Wno-unused-parameter -Wno-unused-variable -Wno-unused-but-set-variable -Wno-sign-compare -Wno-stringop-overflow -Wno-error=discarded-qualifiers -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-label -Wno-pedantic -Wno-error=stringop-truncation -Wno-error=cast-function-type -Wno-stringop-truncation -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -D_POSIX_C_SOURCE=200809L -D_GNU_SOURCE -MD -MQ externals/cgns/hdf5/libsu2hdf5.a.p/H5dbg.c.o -MF externals/cgns/hdf5/libsu2hdf5.a.p/H5dbg.c.o.d -o externals/cgns/hdf5/libsu2hdf5.a.p/H5dbg.c.o -c ../externals/cgns/hdf5/H5dbg.c
In file included from ../externals/cgns/hdf5/H5private.h:27,
from ../externals/cgns/hdf5/H5dbg.c:33:
../externals/cgns/hdf5/H5public.h:63:10: fatal error: mpi.h: No such file or directory
63 | #include <mpi.h>
compilation terminated.
It basically says no file named mpi.h but when I go to my mpich version which is the latest version 4.2.1, I see mpi.h in the include folder.
Could you help me with this issue?
Regars.
sntblm
sntblm is offline   Reply With Quote
Old   November 27, 2024, 12:27
Evert Bunschoten
EvertBunschoten is on a distinguished road
Can you compile any other C++ file that uses #include <mpi.h>?
EvertBunschoten is offline   Reply With Quote
Old   December 9, 2024, 01:37
Andrew Samson
ais_sk is on a distinguished road
This one might be helpful. Have a look.
https://youtu.be/SOh63xwwLOo?si=jsNNZSqdFk2zak-Y
ais_sk is offline   Reply With Quote
mpich, parallel installation, su2
Problems with running in parallel Miguel_M_Valero Main CFD Forum 9 January 16, 2025 01:32
Parallel computation problems with SU2 3.2 akun646 SU2 2 July 19, 2014 13:04
Installation issues for parallel computation Akash C SU2 Installation 1 June 21, 2013 06:26
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 04:35
Installation problems indy OpenFOAM Installation 7 April 3, 2009 10:40
