[Sponsors] | |||||
Rep Power: 9 ![]() |
Hi. I'm trying to compile v 8.1.0. I type ./meson.py build -Denable-autodiff=true -Denable-directdiff=true --prefix=/home/lozanorc/SU2 and at the end of the process it gives an error:
ERROR: Clock skew detected. File /home/lozanorc/su2code-SU2-a991912/build/meson-private/coredata.dat has a time stamp 29.5643s in the future. I then try to run ninja and it fails >./ninja -C build install ninja: Entering directory `build' ninja: error: loading 'build.ninja': No such file or directory Any clues? |
bigfoot
Rep Power: 23 ![]() |
it does not build because some timestamps are in the future, you could try to use the 'touch filename' command to set the timestamp to the current time. But there might be more going on here, maybe a clock that is not synchronized using ntp?
#3 | |
Regards |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| AMD Genoa best configuration for 128 cores Fluent/Mechanical licenses | chefbouza74 | Hardware | 10 | February 22, 2023 12:45 |
| CFD workstation configuration calling for help 2 | Freewill1 | Hardware | 6 | July 8, 2020 22:17 |
| [OpenFOAM.org] Cannot open configuration file mpicc-wrapper-data.txt mpicc: Not found | wenjuny | OpenFOAM Installation | 0 | November 25, 2019 10:01 |
| need therm.dat file for ECFM3Z Combustion model | ankitraut27 | CONVERGE | 8 | July 2, 2019 13:34 |
| Multiple Configuration Simulation | Tristan | CFX | 0 | November 14, 2009 00:01 |
