[Sponsors] | |||||
SU2_CFD_AD not found although I used meson.py to build from source with autodiff |
anonymous
Rep Power: 0 ![]() |
I installed SU2 with the following commands on ubuntu 24.04:
sudo git clone https://github.com/su2code/su2.git sudo apt update sudo apt install mpich libmpich-dev cd SU2 sudo ./meson.py build -Denable-openblas=true sudo ./meson.py build -Dwith-mpi=true sudo ./meson.py build -Denable-pywrapper=true sudo ./meson.py build -Denable-directdiff=true sudo ./meson.py build -Denable-autodiff=true sudo ./ninja -C build install I get the following message with each of the commands: update CoolProp /usr/bin/SU2/subprojects/CoolProp /usr/bin/SU2 CoolProp updated Directory already configured. Just run your build command (e.g. ninja) and Meson will regenerate as necessary. If ninja fails, run "ninja reconfigure" or "meson --reconfigure" to force Meson to regenerate. If build failures persist, run "meson setup --wipe" to rebuild from scratch using the same options as passed when configuring the build. To change option values, run "meson configure" instead. When I tried following the quick start guide to run the discrete adjoint, I get the error saying SU2_CFD_AD: command not found. I did not find the SU2_CFD_AD executable or directory anywhere. Here are my path variables: export PYTHONPATH=/usr/bin/python3 export SU2_HOME=/usr/bin/SU2 export SU2_RUN=/usr/bin/SU2 export PATH=$SU2_RUN:$PATH export PYTHONPATH=$SU2_RUN:$PYTHONPATH export MPICC=/usr/bin/mpicc export MPICXX=/usr/bin/mpicxx Please let me know if I am missing something. Thanks |
bigfoot
Rep Power: 23 ![]() |
sudo ./meson.py build -Denable-openblas=true sudo ./meson.py build -Dwith-mpi=true sudo ./meson.py build -Denable-pywrapper=true sudo ./meson.py build -Denable-directdiff=true sudo ./meson.py build -Denable-autodiff=true sudo ./ninja -C build install In any case, you need to combine the meson arguments into one meson command because else the previous command will be overwritten. Also, you overwrite the previous meson command with the argument --reconfigure. If you do not provide that, the new meson command will not create a new configuration. So you need to do this: Code:
./meson.py build -Denable-autodiff=true -Denable-pywrapper=true -Denable-directdiff=true -Dwith-mpi=enabled -Denable-openblas=true --prefix=~/bin Code:
./meson.py build --reconfigure -Denable-autodiff=true -Denable-pywrapper=true -Denable-directdiff=true -Dwith-mpi=enabled -Denable-openblas=true --prefix=~/bin |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
| [swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
| Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 16:11 |
| [foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
| OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
