Home > Forums > Software User Forums > SU2 > SU2 News & Announcements
Calculating C_l and C_d on the individual bodies in the same domain
Old   November 21, 2019, 08:00
Default Calculating C_l and C_d on the individual bodies in the same domain
Shainath
shainath is on a distinguished road
I am trying to simulate a CFD case where two airfoils of different/same size are present in the domain. I want to calculate C_l and C_d on these airfoils separately. How can I do it? It will be really helpful if you exactly point the part of the configuration file that needs to be changed to achieve it. Thank you.
shainath is offline   Reply With Quote
Old   December 3, 2019, 13:08
Tim Albring
talbring is on a distinguished road
Hi Shainath,
you can use the AERO_COEFF_SURF group to get the lift/drag for all surfaces in MARKER_MONITORING separately. Also look here for more information on the new output: https://su2code.github.io/docs_v7/Custom-Output/
Best,
Tim
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   December 14, 2019, 08:14
Shainath
Hello Talbring,
Thanks for replying. I have gone through the link but could not find the right information. As mentioned in my question, I am using a simple case where two airfoils(e.g. airfoil1,airfoil2) for which I have given the input as
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Navier-Stokes wall boundary marker(s) (NONE = no marker)
MARKER_HEATFLUX= ( airfoil1, 0.0, airfoil2, 0.0 )
% Farfield boundary marker(s) (NONE = no marker)
MARKER_FAR= ( farfield )
% Marker(s) of the surface to be plotted or designed
MARKER_PLOTTING= ( airfoil1,airfoil2)
% Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated
MARKER_MONITORING= (airfoil1,airfoil2)
The results it shows after the convergence seem to be wrong. Please let me know what has gone wrong in this input. Thank you.
Old   January 7, 2020, 14:12
Akshay Koodly
akoodlyr is on a distinguished road
This part of the config file looks correct. Can you share the rest of your input file also?
Cheers.
akoodlyr is offline   Reply With Quote
