[Sponsors] | |||||
Valerio
Rep Power: 3 ![]() |
Goog Morning,
I'm trying to simulate a viscous flow around a circular cylinder (2D) but I can't get the solution to converge. Does anyone have an idea or can explain to me how to choose and set the limiters? It's not very clear from the site how these choices are made. In the meantime I attach the CFG file. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % % % SU2 configuration file % % Case description: Viscous flow circular_cylinder % % Author: % % Institution: % % Date: 2024.12.28 % % File Version 8.1.0 "Harrier" % % % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % SOLVER= NAVIER_STOKES KIND_TURB_MODEL= NONE MATH_PROBLEM= DIRECT RESTART_SOL= NO RESTART_ITER=1 READ_BINARY_RESTART= NO % ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------% % FLUID_MODEL= IDEAL_GAS GAMMA_VALUE= 1.4 GAS_CONSTANT= 287.0 MACH_NUMBER= 5.0 AOA= 0.0 SIDESLIP_ANGLE= 0.0 FREESTREAM_TEMPERATURE= 136.1 FREESTREAM_PRESSURE=4.1 REYNOLDS_NUMBER= 1.8875e6 REYNOLDS_LENGTH= 2.0 % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % REF_ORIGIN_MOMENT_X = 0.00 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 REF_LENGTH= 1.0 REF_AREA= 29.0 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % MARKER_HEATFLUX= ( wall, 0.0 ) MARKER_SUPERSONIC_OUTLET= ( outlet ) MARKER_SUPERSONIC_INLET=(Inlet, 136.1, 592.149, 1169.24, 0.0,0.0 ) MARKER_PLOTTING= ( wall) MARKER_MONITORING= ( wall ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES CFL_NUMBER= 2.0 CFL_ADAPT= NO CFL_ADAPT_PARAM= ( 0.5, 1.1, 1e-4, 2000.0) ITER= 500000 % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % LINEAR_SOLVER= FGMRES LINEAR_SOLVER_PREC= LU_SGS LINEAR_SOLVER_ERROR= 1E-10 LINEAR_SOLVER_ITER= 20 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % MGLEVEL= 3 MGCYCLE= V_CYCLE MG_PRE_SMOOTH= ( 1, 1, 1, 1 ) MG_POST_SMOOTH= ( 0, 0, 0, 0 ) MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) MG_DAMP_RESTRICTION= 0.5 MG_DAMP_PROLONGATION= 0.5 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % CONV_NUM_METHOD_FLOW= HLLC MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN TIME_DISCRE_FLOW= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % CONV_RESIDUAL_MINVAL= -15 CONV_STARTITER= 10 CONV_CAUCHY_ELEMS= 100 CONV_CAUCHY_EPS= 1E-7 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % VOLUME_OUTPUT=DENSITY,ENERGY,PRESSURE,MACH,VELOCIT Y-X,VELOCITY-Y,VELOCITY-Z MESH_FILENAME= cylinder_0.su2 MESH_FORMAT= SU2 MESH_OUT_FILENAME= mesh_out.su2 SOLUTION_FILENAME= restart_flow.csv SOLUTION_ADJ_FILENAME= solution_adj.dat TABULAR_FORMAT= CSV CONV_FILENAME= history RESTART_FILENAME= restart_flow.dat RESTART_ADJ_FILENAME= restart_adj.dat VOLUME_FILENAME= flow VOLUME_ADJ_FILENAME= adjoint GRAD_OBJFUNC_FILENAME= of_grad.dat SURFACE_FILENAME= surface_flow SURFACE_ADJ_FILENAME= surface_adjoint SCREEN_OUTPUT= (INNER_ITER, RMS_DENSITY, RMS_ENERGY, CFL_NUMBER) OUTPUT_FILES= ( RESTART_ASCII, PARAVIEW, SURFACE_PARAVIEW) OUTPUT_WRT_FREQ=(100,100,100) |
Jimin.Zhang
Have you resolved this problem? I've recently encountered the same problem.
Valerio
Hi, I perfomed several cases. In the case of viscous flow I advise you to use REF_DIMENSIONALIZATION = FREESTREAM_VEL_EQ_ONE. Furthermore, the slope limiter depends on the size of your boundary layer mesh. But I don't know what criteria must be followed..
| Tags |
| hypersonic, slope limiters |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Velocity magnitute ignored at inlet for incompressible flows | t.teschner | SU2 | 2 | October 30, 2024 06:56 |
| MUSCL and SLOPE LIMITER IN SU2 | hilmialf | SU2 | 4 | July 24, 2021 07:09 |
| Is MINMOD still an option for slope limiter? | wruudf | SU2 | 5 | October 22, 2014 19:13 |
| slope limiter of discontinuous Galerkin on triangular element(2D, P2 polynomial) | effort8 | Main CFD Forum | 1 | March 19, 2012 10:03 |
| slope limiter and flux limiter ?? | Ameya J | Main CFD Forum | 1 | June 13, 2011 13:05 |
