August 13, 2013, 19:42 |
Rectangular wing Induced drag
milind
Rep Power: 14 |
I was thinking to apply the text book problem of minimizing the induced drag for the elliptic wing loading or the shape, hence i created a rectangular wing n thought of using the same cfg file as of onera case in shape optimization (tutorial problem) with some changes and i though instead of surface movement in z direction in my case i can give movement in x direction in order to get a chord distribution for the optimized wing, well i realized that after some optimization cycle( 9) the flow solver blows up and the drag after actually increasing in 2nd cycle drops down to same as the initial rectangular wing after 9th cyle, and the shape also remains the same. Hence i was wondering where am i going wrong. Allthough i must agree i m using a very very course grid(order of 25000 cells) hence i dont expect a good solution but i would just expect some bench solution for me to know the input cfg is correct. Please help me. I have attached my cfg file. Thank you |
August 19, 2013, 13:23 |
#2 | |
Francisco Palacios
Rep Power: 15 |
The problem that you have proposed is very interesting, but very expensive in computational terms. To give you an idea, to properly capture the induced drag you will need a structured grid with ~10M cells, otherwise the induced drag and the spurious drag are of the same order and a gradient based optimization won't work. A good reference about this problem is http://oddjob.utias.utoronto.ca/dwz/...nduceddrag.pdf Once you have the proper grid, my recommendation is that you should fix the trailing edge and move the leading edge to change the platform of your geometry. You should keep in mind that in sharp edges (like trailing edges) the gradient computation is much complex. Thanks for using SU2. Best, Francisco Quote:
August 19, 2013, 14:18 |
milind
Rep Power: 14 |
Well yaa i realise the importance of grid independence, but i was wondering if I can just have around 2M mesh n then if I try i would get something, for that i wanted to know if my cfg input file is correct hence i thought i should probably start with a very small grid and as i increase the grid size i should see how the shape becomes clearer and clearer, Is it possible that i optimize the rectangular wing with the spurious drag and as i increase grid size my solutions become better.
Thanks |
Display Modes | |
Calculating Induced drag of a wing from Trefftz plane analysis in FLUENT | pratikkr | FLUENT | 0 | May 16, 2013 15:14 |
Negative Fuselage Drag on a Tandem Wing? | mmn1239 | STAR-CCM+ | 3 | April 28, 2012 09:20 |
Negative Fuselage Drag on a Tandem Wing? | mmn1239 | Main CFD Forum | 1 | April 7, 2012 05:52 |
Isolating wing induced drag component | siw | CFX | 2 | June 22, 2010 11:21 |
multi wing element - negative coefficient of drag? | Zweeper | FLUENT | 10 | March 11, 2010 13:20 |
