July 23, 2013, 09:42 |
Drag under Euler formulation
MENDES BORTOLAZZI Andre
Rep Power: 12 |
Hi developers,
I would like to ask you how the drag of a profile is computed using Euler analysis. In another post, I've been told the total drag was computed by integrating over the surface, but how is the shear stress tension localy computed? Are the concepts of displacement thickness and momentum thickness employed? Thanks in advance, Andre |
August 19, 2013, 12:32 |
#2 | |
Francisco Palacios
Rep Power: 15 |
Hi Andre,
To compute the Drag (inviscid and viscous) we perform a direct integration of the forces on the surface. More details in http://su2.stanford.edu/documents/SU2_AIAA_ASM2013.pdf And the subroutines in the code: void CEulerSolver::Inviscid_Forces(CGeometry *geometry, CConfig *config) void CNSSolver::Viscous_Forces(CGeometry *geometry, CConfig *config) Best, Francisco Quote:
August 20, 2013, 08:14 |
Rep Power: 12 |
Hi Francisco,
Thanks for your reply. In the end, I guess I was just strugling with spurious drag, because SU2 provided some small values for drag coefficient when running a bidimensional Euler analysis in low Mach flow (thus, no drag). I was confused, because the spurious drag was increasing with the angle of attack, but after some research, I found out this is the normal behaviour for numerical drag. Thanks again for your attention. Best regards, Andre |
Drag law customization (Euler) | Aris | FLUENT | 0 | December 1, 2006 09:39 |
Dimensionless formulation of Euler equations | jvn | Main CFD Forum | 3 | July 8, 2004 13:29 |
Drag formulation | REMY | FLUENT | 0 | March 10, 2002 14:05 |
Drag formulation | remy | Main CFD Forum | 0 | March 10, 2002 13:05 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
